I am having issues with either the spindle not turning on when I start a job or it powering off in the middle of a job. If I run the test through the MDI it powers on and off fine. Using carbide create for the file to run in carbide motion. machine is a pro XXL with a hdz if that matters any.
Thanks
Send M3S12000 through the MDI screen in CM then gently wiggle the wires where the VFD connects to the Shapeoko PC board. Does the spindle cut out and VFD display change?
