Using CC Pro build 514
The Add Shape function is fun, but boy is it a pain in the rear when you can no longer see the inputted values for your Component after clicking the Done button. It would be even better if CC Pro allowed users to fully edit previously Done’d components.
I frequently build projects with three or more stacked Components and end up tweaking the Component values several times after defining the full toolpathing. Unfortunately “tweaking” Compnents usually means deleting the existing Components completely and re-adding them from scratch - hoping I remember or wrote down the Components’ values I don’t want changed.
(I find I don’t tweak Base Height or Add/Subract/… nearly as much as say Shape, Angle, Height Limit and Height - especially Height)
-Mark
