I have the bitrunner setup on my my machine, and when pausing a job and killing the spindle(router) for safety (with the switch and button). Once I start the job however there is no “Hold for spindle”, while this isnt a huge problem because I can unwind it and have it ready to go. But even at 18000 RPM my spindle is a little springy and needs 2-3 seconds to settle in, the pause command doesn’t give it that, It just happily kicks right off. And because it has staged the bit right above the work piece it is often starting the cut before getting to speed.
Is there a setting or a command that I can add time to that resume pause to give my router time to ramp properly before it just runs the too slow bit into my job?
Winston, Thanks for the quick response. I think I am just going to drop that feed rate till it leads in. That will ramp me slowly into it. I feel like getting into direct Gcoding live might be a rabbit hole that will take more than I have
