I am having difficulty trying to get gridlines for my wasteboard. I used polyline on 2 inch square first vertical and then horizontal returning to the point of origin. When I try to do the tool path for vee bit, I get blue diagonal lines and the tool paths are diagonal. The drawings are vertical and horizontal, but the tool paths are diagonal. What am I doing wrong?
A vee bit toolpath cuts in between lines or interior of shapes. My guess is you made a square using the poly lines and it is doing a vcut of each individual square. If you preview the toolpath does it look like half the squares are being cut? I would use a contour toolpath if you want lines cut.
