I had someone ask me to do a waveform for them. They supplied the wood, stained it and most importantly the waveform.
I believe the wood is Alder, it measures 31" x 10.5" x.75", He used an Ebony stain which turned out pretty good. I was afraid it would soak into the wood and might not let the vcarve have a crisp contrast but it wasn’t an issue.
Bits used
.25 3 flute end mill
.0625 2 flute end mill
30 degree v- bit
60 degree v bit
Turned out pretty good, although I did have some issue with the flatness of the board https://youtu.be/xmh3_MDq7pY
Seriously, I think this has extremely high nerd potential. I wonder about the licensing aspects if you were to use a recording from a movie, for example.
Create a waveform for the sound of a light saber starting up. You won’t be able to make them fast enough (until Disney comes over and burns your house down).
If there were a phone app that you could take a picture of a wav form and have it convert that to sound…sort of like a barcode…that would be the ticket.
Jeremy, what were your steps to get the clip ready for whatever CAM program you used? My initial thought is to open the clip in Audacity and snipping tool the wavform, save it as a jpeg, bring it into Inkscape and do a bitmap trace and save that as an SVG (I haven’t tried it so that’s probably not going to work).
Nah a waveform visualized this way isn’t enough info to reverse engineer the sound that created it. But I love the idea and may use this as a gift for the next couple I know who gets married.
Yeah I’ve seen something similar where they use a photograph but when viewed through the app it will play a video. In both cases it’s using image recognition algorithms to determine what it’s looking at against a database which has the original video/sound/etc. Very cool technology.
