What could be causing this Error? on a 5 Pro with vfd
New 5 Pro with vfd. What would be causing this error?
This is what is listed in the carbide 3d docs.
And a link to all alarm codes.
https://carbide3d.com/hub/faq/error-codes/
hope this helps.
:smiley:
Is the BitZero LED red or green to start with. Should be green, if red something is shorted.
Regards,
Allen
Not sure about SO5 but the SO3/4 if the magnet for the Bitzero is grounded the probe cycle will fail. So see where your Bitzero magnet is. You can also power up, connect, but do not initialize and go to settings and debug to see if anything is activated when it should not be.
