22 gauge - 18 gauge copper sheets 1/32 end mill - I run .003 at 6 - 18000 rpm - I have air assist, so my nomad seems pretty happy. End mills last about about 2 - 3 hours of cutting time. I have also tried quite possibly all the 1/32 end mill on the planet. I buy US or Can made (quite possibly the CAN one are US). I also find copper from the Jeweler supply houses works best.
The bases are black walnut that was machined on the nomad as well
The pieces are 6x7
are you enameling with an oven or with a torch?
I have a Paragon SC2 kiln
On a side note the mushroom white dots are COE 90 soft white glass. I used the handheld glass torch to apply the dots after firing in the kiln, then re firing to soften the dots. I think they came out awesome.
Damn, what you can do with artist talent and manufacturing bent !
Beautiful
kiln makes sense, very nice results. and yes the dots did turn out awesome, good work!
Wow. That’s some beautiful work. You’re an artist.
