I’ve been chasing down ± .8mm of squareness or more on my Pro XXL for over a week and am ready to just throw in the towel. I’m not sure why but I have my SO3 cut more square than the Pro at this point. I’ve reassembled the machine 3 times, tweaked the y belts to get them matched tension and no matter what on cuts and an indicator I can’t seem to get the machine any better than that. It’s maddening because if I set my aluminum plates squared up to X all my Y cuts are not coming out right and creates a mismatch when I flip sides for machining. When the gantry is pulled up to the front of the machine everything touches up but I’ve got gaps in the back. Is this about as good as people have been able to get with the xxl pro or di I just get unlucky? My only thinking is one of my main extrusions is off compared to the others
What do your diagonals measure?
Please let us know how you are determining this out-of-squareness at support@carbide3d.com and we’ll do our best to assist.
I’m using a dial .0001” dial indicator. I noticed the symptoms even in smaller parts of the gantry not running square when I was trying to true up a 3”x3” square piece of aluminum. I was contouring the outside to a depth of .55” and then flipped it and it was leaving a non parallel cut in the Y side because I trammed in the x side. So first I swept the y rail with the indicator for the length and noticed it wasn’t square. I assumed the extrusions may not necessarily be flat so I then use the longest parallel I had and repeated. I even noticed when I was flattening the waste board the when it was pocketing towards the front edge it was on an angle. It seems the flaw in the hybrid table design is if something is off when it goes together the table instead of straightening things up to square it basically locks it in because I’ve disassembled the machine 3 times hoping I could figure out what’s going wrong . That’s why I was asking is this as good as it gets with the pro. My expectations were that the pro was going to be much better but I seem to have stumbled on to the biggest design flaw with the hybrid table if you want to use it for something other than basic sign work. Even in my case if I was doing a sign things that have borders will appear out of square
The way mine worked was I measured the diagonal while the parts were all still loosely fastened, gently nudged the corners until things were equal, then tightened the hardware gradually, re-checking the diagonals every so often to ensure that they didn’t shift.
If that doesn’t work for you, let us know at support@carbide3d.com and we’ll do our best to sort it out w/ you.
Yeah this last time I was doing the exact some thing. Problem I was running into was I could never work out the same issue with things loose. It exaggerates it when I finally tighten things back up. I have a theory that something is not cut square or is bowed on one of the Y rails. I don’t know if I have the energy to take it all apart for a 4th time. I know the standard response is it’s a hobby machine and all things are an approximation don’t expect it to be perfect but even a few thou out on small parts sort of defeats the purpose. The best and worst part about the old design was you could sort of shim and twist it into the desired shape and it would hold pretty darn well once it was there. In this case once things are set your sort of on a one way ride. I’m also afraid constantly taking this thing apart is eventually just going to wearout the threads in the aluminum. I haven’t had it a month and I’m still working out bugs to make parts. Luckily I finally got a replacement z proximity switch that seems to have fixed that issue. This seems to be a bigger problem though. I’ve disassembled and reflattened so many times now I am almost to the point that I’ll need new mdf for the hybrid table. Everytime you take the boards off and put them back on you have to reflatten the table because they aren’t parallel to the gantry.
I’ve seen a lot of different advice on how to square/calibrate. I found this video to be the most inclusive on how to really dial in super accuracy. There’s a part about squaring and how you can edit settings in CM if you’re not measuring square perfectly. IMO, the videos put out by Winston and Samcraft only touch the surface of calibration, but this guy takes it to a whole other level.
I’ve certainly been down the rabbit hole tuning the SO3. There are some things about the Pro that are improvements but at the same time introduce new problems. I’m sort of finding out that with the SO3 I could push, twist and shim my tolerances into improvement, the Pro seems to be much more sensitive to belt tension squareness and how tight the tolerances are for the machined table components and the rail extrusions. I’m still working out gremlins. One problem I’m having that it appears others have had is the belt tensioning on the Pro won’t stay tensioned on mine. If I don’t have the bolts for the tension clips cinched all the way tight the belt won’t remain in position. Its the latest thing on my laundry list of emails to Carbide. The assembly instructions tell you not to tension the belts all the way, but on my machine no matter what I do if its not all the way tight the belt slips in the clip. I think the mounting hole is positioned incorrect relative to the clip hole such that it doesn’t keep the belt pushed down on the y extrusion, it also makes it extremely hard to install the clip. Its very well possible that is why I’m losing squareness.
