One of the great questions of the ages… some say it is an anti-theft device for in store sales, other rumors say that it may be a ferrite coil to reduce emi…I just slid it out of the way and still wonder what it is. To remove it I would just use a dremel and slice it open.
I would guess it is anti theft
Griff
(Well crap, my hypometric precursor device is blown…)
3
Yep, anti theft. Squash it in a vice or vice grips, easiest way to remove.
Could be anti theft but looks a lot like a ferrite bead. Either way it wont hurt to remove it. If it is a ferrite bead and you start having disconnects you can add one back on.
That is a rather large ferrite assembly to keep your Makita from adding its brush arcing noise onto the power line.
You might want to add more of them to the line, but if you want to join the “League of Disconnect Victimhood”, removing this might be a good way to do it.
Perhaps the anti-theft company behind these products deliberately makes them look like ferrite cores so that when they are on display in Big Tools Depot, Mr Ima Burglar can’t see an obvious tag/dongle to remove before they perform their nefarious task ?
