gregory
(Greg)
January 16, 2025, 8:45am
1
I hear a noise when I jog the Y axis of my machine. It isn’t always at the same place, but it’s only on the Y axis and only the right side.
Here’s a video https://youtube.com/shorts/jH1pTwCUdm0?si=FneAD-0Wa5vQnHrb
In the video it sounds a little crunchy. In person it sounds a little more squeaky. I suspect it’s the belt but I’m not sure.
Ed.E
(Ed)
January 16, 2025, 1:51pm
2
Maybe remove both Y axis belts then move Y all the way from front to back. That may be a way to help pinpoint the problem.
GeorgeMM
(George )
January 16, 2025, 1:57pm
3
Or feed that duck … maybe the duck’s stomach is growling from hunger!
I had a similar noise…turned out to be the wiring for the Y axis…I could giggle the wiring and the noise went away. Redid my ties and all is good now.
gregory
(Greg)
January 21, 2025, 3:59am
5
Update - jiggling the wiring had no effect. I removed the belts and the squeaking is gone. I noticed that the belt gears are pretty dirty:
I have 3 new belts on order, and I’ll clean out those gears as best I can. I bet that fixes things.
gregory
(Greg)
February 6, 2025, 2:23am
6
I cleaned the gunk out of those gears with a nylon brush, and I replaced the belts, and the sound is gone. I’m not sure why but it actually sounds “cooler” now, maybe belt tension or something.
system
(system)
Closed
March 8, 2025, 2:23am
7
