I have read that a sealed tablet is probably best for use with the Shapeoko but, although we have owned seven Macs and about a dozen PCs, I know nothing about tablets.
I would welcome a suggestion on what to shop for.
I have a dedicated surface pro. Iāve had no trouble with it whatsoever.
This is exactly what I use. Itās got a fan but the fan hardly, if ever, runs so it isnāt constantly sucking in dust
I use a Toshiba Encore 2 Write 10 and Samsung Galaxy Book 12 (both discontinued).
The Surface Go has worked well for some folks, with others complaining of performance.
The RCA Cambio continue to be available and popular and works well for folks who limit its usage to access to a network file store and running Carbide Motion despite its failing to meet the system requirements.
If budget allows, Iād suggest getting a 64-bit machine.
FWIW, Iām still waiting on delivery of a touch screen and case for my Raspberry Pi.
Whatās with this Raspberry Pi, thingy?
I baled from Windoze machines after a backup didnāt, and I lost all my data - yep, every flippinā bit of it - and settled on a Mac and time machine backups, which has not let me down since.
But my Macbook Air is also a bit dated, now not supporting the Big Sur upgrade and not very good at keeping a charge, and theyāre a bit prohibitively priced for a retired old git like me!
Earlier comments made me look at a Raspberry Pi, which is less than Ā£200 (rather than just under Ā£2,000!) but I canāt see how it could replace a tablet or laptop.
Does it, and what else do I need to know? Iām assuming it wonāt run CC, but will run CM?
Thanks
Peter, check this thread. Carbide Motion on a Raspberry Pi
I picked up the 10.5ā touch screen linked in the thread. That and a Pi are all you need Sub $200.
Correct, there is not (yet?) a version of Carbide Create for Raspberry Pi.
@clintonmagus hereās a well reviewed option for a win10 tablet that I have if you want something to run both CC & CM.
CHUWI Hi10 X,10.1inch Tablet PC,Windows10 Intel N4100,Quad Core 6GB RAM 128GB ROM,1920X1200 IPS Screen,Type-C,BT5.0,WiFi,2 in 1 Tabletļ¼6GB,128GBļ¼
by CHUWI
Learn more: https://www.amazon.com/dp/B08319MF76/ref=cm_sw_em_r_mt_dp_9470BQM1JYS5F1HNCD4X?_encoding=UTF8&psc=1
I use a Surface 5 on an XXL. My son uses a Surface 7 on his XXL.
