Being from Florida I am pretty familiar with dealing with hurricanes. Everybody knows that you would rather be to the west of the storm than the east. I am guessing that this might apply to CNC’ing when doing metals or plastics where running material you already cut free is a concern.
Would there be any benefit to doing a counterclockwise path, versus clockwise, with a clockwise turning cutter when chip clearing is a concern?
Thanks for the response. Now I have a concrete name to go with the concept I had in my head. Since the context here is milling metal, climb carving puts extra stress on the machine, and we are talking Shapeoko and not an industrial machine…I would say climb cutting is out for that use case. It may be an option, but probably of no benefit when cutting wood.
At the moment CC indeed only supports conventional (which is fine for many, many usecases).
Fusion360 or VCarve (and several others) allow one to choose the cut direction when generating the toolpaths.
Yes, one can control path direction if one is willing to arrange geometry so that one can then do a contour toolpath which will be in the desired direction, so if:
