I tried looking around to see if anyone had the same problem, but had no luck. What happened to all the fonts that were already loaded into create? I no longer have any of the Ariel fonts or Brush script. Can anyone help me out? I have the most updated version.
Maybe check those tips from @WillAdams?
Checked there. No fonts there. Had them all two weeks ago and now they’re gone.
If fonts no longer appear, it is because the OS is no longer affording access.
It may be that you’ve exceeded the number of fonts which QT can manage — try uninstalling fonts which are not needed.
It may be that permissions have changed — check the install permissions for the fonts.
If you have fonts you specifically want available in Carbide Create, copy them into the Carbide Create\fonts directory as noted in the link above.
