OK, so I had another look at this today, after taking out the waste board and using the baseboard as the datum point, after checking the horizontals and verticals with a spirit level.
The problem was still there, i.e. front to back with the wobbly stick was fine, but side to side had a 6mm difference.
I slackened the screws to the adjust the tramming plate on the Z-Plus plate, but could only adjust it by 1mm either side, so the difference is 4mm - at least an improvement!
I then loosened the router mounting clamp and had a play with that, tightened it up, rechecked the tramming with the wobbly stick and it appears to be perfectly in line - at least for now.
I’m expecting a flattening bit to be delivered over the next couple of days, so I’m going to run a project to give it some work to do, then check it out again. Fingers crossed!
Thanks for your comments and suggestions, guys
