I turned away for a moment…and my collet slipped as the bit hit a knot, the bit loosened and before I could stop the machine, the bit traveled through the bottom of the piece into my spoilboard and things shook a lot. When I finally got the piece out from under the bit, I found this screw sitting on my spoilboard.
I’m 99% sure it’s from the Shapeoko, but I could not find where it came from. All screws seem in place. I’m not going to run the machine until I found its home.
Just the first of a dozen tapes I found in my shop. It’s a “Center Finder”. It’s a gimmick measure for the mathematically challenged…you measure a piece with the inch side, then find that same mark on the other side, and you have the exact center.
OK…Mike from support solved it! It’s the set screw for the Z axis belt tensioner.
A little tough to see there (and a b#$% to get in without taking apart the whole Z Axis…but I did it).
