Which CNC for a hobby workshop in Germany? Shapeoko — XL or XXL, Pro worth it, hybrid table?
Hi all — I’m planning to buy a CNC router for a hobby workshop in Germany. Must be orderable here (or shipable to DE). Main use cases: hobby projects, gifts and small furniture (cutting parts, pocketing, joinery). Optional: I’d like the option to add a laser later, but it’s not mandatory.
So far I’ve been looking at the X-Carve and the Shapeoko (w/ Shapeoko 4 / Shapeoko Pro). A few specific questions I’d love experience-based answers to:
  1. Which machine would you pick for a hobby woodworker / small-furniture maker (X-Carve vs Shapeoko)? I care about reliability, community/help online, upgrade path (laser, dust collection, auto-tool-setter), and parts availability in Germany.
  2. How big do I need the machine to be? XL or XXL?
  • I’ve read the Shapeoko 4 XL gives you a large X travel but smaller Y, while the XXL gives a full square cutting area. Is XL usually sufficient for most hobby furniture parts, or does XXL end up being worth the extra footprint and cost?
  1. Shapeoko 4 vs Shapeoko Pro — is the difference noticeable in everyday work?
  • I’ve seen notes that the Pro uses linear rails and bundles some extras (e.g., BitSetter) while the Shapeoko 4 uses the V-rail/wheel layout. In real use — rigidity, finish quality, ease of setup — is the Pro a clear step up or only incremental for hobby use?
  1. Is it worth spending a lot more for the Pro/5.1 (or equivalent higher tier), or will the 4/standard models do 90% of what I need? Any real examples where the Pro saved the day?
  2. Hybrid table (T-slot + spoilboard / vacuum) — useful or overkill?
  • Is the hybrid/ T-slot table worth buying from the manufacturer, or do people usually just make a flat MDF spoilboard / T-track table themselves that’s “good enough” and just as stiff? Any pros/cons from using the hybrid table in daily work?
  1. Laser add-ons: If I want the option for a laser later, which platform is more plug-and-play for laser upgrades? Any cautions about safety / software support in Germany?
  2. Availability / shipping to Germany: Any tips on buying in Europe (resellers, shipping, customs for Carbide 3D / Inventables parts)? I’ve seen some sellers in Europe but not always consistent stock.
If you have pictures or example projects made on XL vs XXL, or you can share how you mount big panels / workholding strategies, that’d be fantastic.
Thanks a lot!
Phil
  1. Folks use and sell Shapeokos here, so there’s your answer
  2. My recommendation for machine size has always been: if your parts fit on it, get a Standard or 2x2 or HDM), if you work w/ boards get an XL (or 4x2), if you work w/ sheet goods get an XXL (or 4x4)
  3. The Pro is a clear step-up in terms of potential material removal rates and easily achieved surface finish — a 4 can achieve similar results, it just takes longer
  4. As part size and complexity scale up, machine time multiplies — the added rigidity and better surface finishes of a Pro or 5.1 pro or HDM function as a dividing factor to allow one to finish parts more quickly and more easily and more reliably — see above
  5. The Hybrid T-track is amazing and easily one of the best things about our machines — the only con for it is that it’s not available separately and I often find myself using my machine bed as a workbench
  6. No idea on lasers
  7. I would recommend purchasing from a reseller — if you have difficulties with that, please check in w/ the folks at sales@carbide3d.com
https://carbide3d.com/projects/
Have you looked at Stepcraft, are they not German?
Why cross the creek to get water, unless you want to.
I guess the availability in DE, shipping cost, import duties are the first step to consider for the initial purchase, but you’ve likely also included ongoing parts, service, warranty time frames and cost? Getting a replacement cable or small from an company in a day or two is easy if you’re in the same country or customs zone, but maybe not so easy if it has to cross an oceans?
What are your thoughts on the RatRig platform from Portugal?
And @BrokenEndmill mentioned Stepcraft. Looks like the M1000 model is 5K USD. A comparably-sized Shapeoko 5.1 is 3.5K. Certainly more expensive, but IDK what shipping and customs are to get the 5.1 to DE from USA.
There are also the Genmitsu’s and QueentAnt’s of the world.
Either way, good luck with the purchase. Post back when you decide.
I have experience with both, and clearly prefer Shapeoko. xcarve did not have a bitsetter, it was a nightmare to change bits in a project, was clearly just for the beginning hobbyist. I had the machine (“plain” xcarve) before they developed the xcarve pro, and I clearly would prefer any shapeoko before the XCarve. Probably different with XCarve Pro. The precessor I had obviously is not available with Inventables any more.
Online community is great with Shapeoko.
For furniture (I made some chairs from plywood) one usually cuts thicker stock, therefore I srongly recommend a Z-independent dust system. It looks like xcarve pro comes with one of those, the shapeoko does not come with such one. There are some z-independent dust boots available, but not optimal.
If you have the space: think of what they say about cars: what is better than many horsepower? More horsepower! Same goes with size. One always can make smaller projects on a large machine, the other way around is not compatible with basic principles of physics.
And then you have double the price with xcarve compared with shapeoko.
I find my shapeoko Pro XXL a pretty decent device, the flexibility of the belt drive needs some workaround, what in the end equals time. The 5.1 pro is -according to c3d- much stiffer and has ballscrews for all axis’, like obviously the xcarve. So with less flexibility one can cut faster, means gets more done per time.
A really big pro are the hybrid workholding tables of shapeoko. That system is genious.
For both consider: the service with C3d is great, they always respond within very short time, and they ship very fast. There is time shift if it comes to phone or video service.
BUT! there is transit time for replacements. In this country it is at least one to two days. Over the Big Pond that is a different story, the German custom people additionally are sadistic pricks if it comes to something from USA.
Seriously consider a German manufacturer just for that reason.
Viele Gruesse uebern Teich,
Note that the Shapeoko 5 Pro and HDM afford the option of an independent height dust boot in the Sweepy Pro:
looks decent. Anyone experience with that dust boot on a shapeoko pro, any trick to attach it somewhere?
It’s specifically for the HDM or SO5 Pro only — it requires a couple of holes, some of which are threaded and the Z-Plus and HDZ for earlier models don’t have those features.
Thanks a lot for the input guys! The more I research, the more machines I find. There’s also the Stepcraft D.840 and the Sorotec Hobby Line. Both are a bit cheaper than the Shapeoko XL Pro with the hybrid table. Or something completely different again: DIY kits like the Ultimate Bee, Queen Ant, or RatRig. That’s a huge selection, and at the moment I honestly have no idea which one I should choose. I’m also not fully aware of all the differences between them.
I am sure that the folks at sales@carbide3d.com will be able to assist you with any further questions you might have on our machines.
Are you completely new to CNCs, or do you have prior experience? Buying a new machine without experience would be really intimidating.
Any chance there is a makerspace with a CNC near you? I got some basic training in a local woodshop and learned Vcarve Pro before I got a machine at home. I wouldn’t have had a clue about buying a machine otherwise.
No, I’m a completely nooby to this topic. But I think there is no markerspace or something like that in my area. Would be a great idea tho!
