Does anyone have a sheet with all the standard Speeds and feeds for whiteside bits? I want to use the CNC carving set 705 from whiteside but haven’t been able to find speeds and feeds for them.
Have You tried reaching out to Whiteside?
You can actually download the tool feeds and speeds directly from white side for all of their tools into Vectric. https://www.whitesiderouterbits.com/pages/vectric-tool-files
If you don’t own it, you can probably still use the trial version to look at the details. (They allow you to do everything just not export Goode).
The one thing to be wary of, is that I believe the feeds and speeds may be designed for a more industrial machine, so you will need to tone it back. I know that @wmoy used this brand for a while and should be able to confirm the amount of reduction required to work with a Shapeoko. Otherwise I am sure their are others on this forum that would know.
If you email Whiteside they will respond with the individual and/or list of tools you want F&S for. They responded to me for my fly surfacing bit. They use a form on their website and not just an email address.
The speeds and feeds are on Whitesides websit in the catalog.
