I have an issue where my pocket cuts have an odd shape in the corners.
You can see it in the photo, bottom left corner shows this the most. Any suggestions on fixing. Is this a belt tension issue? Play in the Z? Any suggestions welcome
Iβd guess either an incorrect/imprecise bit diameter or poor belt tensionβ¦ or stepper sprocket slipping (tighten the set screws).
With the machine on, see if you can easily move the carriage along and and/or y. If it moves a small amount (1/8" or so) without any resistance that might indicate a loose set screw on the motor shaft pulley.
One possibility is simply a matter of the toolpaths β try leaving a roughing clearance and making a final finishing pass.
Electro-mechanically check:
Thank you all for the help and suggestions I will try all of this over the weekend. I really appreciate the help!
