randell
(Randell Hodges)
January 30, 2020, 3:14am
1
I’m looking at the assembly guide for the standard sizes shapeoko and it shows the wires coming out the top.
My electronics box has the hole on the bottom, if I have the USB/power on the right side like the picture shows.
Was the design changed, or am I doing something wrong?
Nessk
(Kenneth)
January 30, 2020, 3:26am
2
Randell,
It sounds like its all correct on your machine, just that the warning regarding the pictures where missed.
Edit: Also I do believe that they changed the design, I have 3 holes and the orientation of it matches the picture in the Assembly guides you linked to.
randell
(Randell Hodges)
January 30, 2020, 12:45pm
3
Thank you for that link! I just skimmed it, but it L oks like that is exactly the information I was needing.
Edit: From the guide you posted, indeed, coming out the bottom:
“On the Standard Model Shapeoko the Connection side will face right, the wire exit location will point downwards.”
system
(system)
Closed
February 29, 2020, 12:50pm
4
