Wood joinery resources
This is a 120 pg. PDF:
which seems to cover everything from the very basics.
Thanks Will!
You are always there for helpful advice and info.
you always seem to have great info to share Thank You Will
Changed the title here to be a bit more general.
Came across this old blog post:
which includes a video showing a “cogged scarf joint” used in chairmaking.
All of this has me wondering what sort of joinery was used in a pair of lacquer chests my folks bought when I was quite young…
Not wood, but this might be an interesting option for some folks:
In particular, I could easily see working up a multiple part piece in metal, hiding the screw holes on the interior, and then machining wood to fit it.
This blog post goes into a bit of math on glue surface and theoretical strength:
