Looking for some recommendations for workflow to turn a simple jpeg image into a grayscale image which can be used for 3d relief carving.
See the thread here.
Do you have Carbide Create pro, it will import PNG and JPG into the modeling tool to make 3D images. You can also make you own from scratch.
$125 ish per year.
I have some youtube videos on how it works. Channel is Stephen k cox.
You can see if this is what your looking for.
The problem is, very few images have a direct mapping between dark/light and height/depth — if you have such an image, it will make a model as expected — if you don’t, you will be better served by:
If you have a suitable pixel image, then w/ a Pro license just use:
Import Image (second icon from the left)
