I’m looking for guidance/recommendations for managing the GCode going forward. I’m currently running CC636 and CM542 and have downloaded CC652 and CM569.
My project is simple. It contains 2 toolpaths. One contains circles, the other squares. Each group of circles or squares is exported as a separate .NC file. My workpiece is .75 thick. In CM, I load one or the other and cut to a depth of .38 (just half past thickness). CM stops and I unclamp/flip the workpiece over and cut the other pattern to the same depth. The finished piece serves as a hot plate trivet where every intersection of the patterns creates an opening to diffuse the heat away from the counter.
I understand that the ability to group toolpaths and export them into separate Gcode files will not be carried forward past CC652.
? - is CC652 the last release in the CC6xx series?
? - Assuming I stay on CC652, will all releases of CM going forward continue to work properly with .NC files?
? - If I upgrade CM, i assume it will be able to sense the filetype and isolate the GCode accordingly?
? - Will CC7xx or CM contain a browser to look at the gcode. Many forum requests for help end up with “Send me your gcode”.
? - If I chose to upgrade to CC7xx, it seems that to be able to cut only squares or circles I would have to create two .C2d files, one for each?
I appreciate and info you can provide.
Regards,
Wayne
