I hot glued a small wedge (ramp) for the chain to follow when it came to the end plate. Simple and works like a charm. I can send pix if you like. Ok, I was able to upload the photo.
You are welcome, sometimes simple is best. It took all of 5 minutes and got me up and running again. I meant for it to be temporary, but has been fine for months. It’s not pretty, but effective. Don’t mess with success!
Here is a vote of confidence for one of the solutions above by fiero1.
I just put my Shapeoko 3 XXL together today. I had the above mentioned problem where the limit switch interfered with the x axis drag chain. The limit switch was mounted from the factory so that the switch was on the side of the plate toward the back of the machine. I followed the suggestion by fiero1 above and now I don’t have interference. It is very close and will keep an eye on it for a while but it does not touch. The limit switch now is made by touching the belt clamp. But that will probably be OK.
Hey, this issue has been bugging me for a while. I just found this thread, and moving the limit switch to the other side of the plate fixed it–works great now.
