Unfortunately my local hardware stores (even Home Depot) did not carry any M4 8 mm Allen head screws so I settled for these.
I can travel to another Home Depot about an hour away tomorrow after work and grab some. I might grab both 8 mm and 10 mm just in case. I’ll swap them out and realign the flats
Agree - I would use the longer set screws I mention in the post above (M3x8mm for the S3) and make sure you’re getting good contact with the flat surface. Try that, re-tighten everything, and run your tests again.
If belts and mechanics are good and it’s still happening after you adjust those set screws, my next thought it check your wiring. Reseat the motor cables, check routing for interference (laying right on the router power cable, etc.). Then you can flip motors from one axis to the other, see if the problem follows a motor.
If there is a problem with the Y-axis, check it by:
powering down
removing both Y-axis belts
putting a bit of tape on the Y-axis pulleys so as to more easily see their rotation
powering up and initializing
The machine should initialize the Z-axis as normal and then try to move the X- and Y-axes — the X-axis should also initialize as normal while the Y-axis motors should turn until they time out — do they turn evenly and in synch?
Power down and re-install the Y-axis belts if they are in good condition, swapping them end-for-end and side-for-side.
I have the correct screws and tried to realign both y axis pulleys but the shafts are stuck and will not budge. They are both misaligned and I cannot turn them correctly without busting them haha. I guess they are loose enough to fidget on certain cutting operations but too tight where I cant actually adjust them
I will contact Carbide support and see what my options are
Goat screw indeed. Good news is support believes that if it wont budge, its likely not the issue. Which means the bad news is the issue is still unknown. Ill put everything back together and run another test cut after work just to see where im at
Just for peace of mind, it would good to remove the sprocket with a puller, clean up any damage to the shaft with a file, put the sprocket back on and align the screw with the flat.
It’s been a while, life got a bit busy, but I do have updates. Carbide 3D sent me a replacement motor due to my shaft being a bit messed up. I installed it, lined up the flats properly, installed the new screws with threadlock on the shaft. I also cleaned the pulley, pulley wheels, and bearings. I had noticed a build-up of rubber and dirt grime.
I ran my test cuts and they came out perfect, no more weird shifting occurring. My best guess is some sort of slipping was occurring
