Hey makers -
I came across the Meyers Woodshop video for a Rii mini keyboard controller to control the Shapeoko. I picked one up on Amazon only to realize my Mac doesn’t recognize it.
Are there any Mac users here that are using something different to jog your machine? Is there an app for the iphone, perhaps?
I just use a regular usb keyboard that sits next to the machine. The arrow keys and +/- control everything and it’s pretty easy to do it without looking now.
Thanks Ryan -
That’s the route I wanted to go as it seemed the most streamlined. The Rii I purchased isn’t being recognized… maybe just not compatible w/ a Mac.
Thanks Will - could you step-by-step this for me? I’m not following you.
Knowing my computer’s IP, from what device (iphone?) do I connect using port 8080? Are you speaking in terms of running the machine from my phone?
If so, is there a ‘bridge’ program to make that work that has controls for jogging X/Y/Z? You mention there’s no app needed but what do I use as a controller?
Technically this works. However, the jog functions from the iPhone are pretty erratic; each press of the button does not necessarily equate to one increment… I won’t be using this to jog the machine.
I have trouble with duplicated button presses on some machines as well — usually I’ve been able to work around this by reducing the increment of movement — please put in a note on this to support@carbide3d.com so that we can have that specific note on it not working on your machine.
I use the Rii keyboard with no issues on my MacBook Air over Bluetooth. So it is definitely possible, maybe I can help if you have a specific question?
First, after connecting the keyboard to the Mac with Bluetooth, make sure the “Jog” window is open on Carbide Motion.
Second, press the number 4 key on the keyboard to set your increment to full speed. Initially my speed was set very low and it didn’t seem like it was working.
Thanks John -
I ordered this (knee-jerk purchase) from Amazon without realizing it didn’t indicate iOS… looks like some of the Rii keyboards mention it and some don’t:
