XL x-axis limit switch
So i finally installed the limit switches and am finding that when i home the machine, the x-axis switch mounting bolt gets hung up on the drag chain. Suggestions?
I ran mine on the other side of that bracket,mabie worth a try?
I did as @orlrobinson did, and added washers to the spacers. http://www.shapeoko.com/forum/viewtopic.php?f=37&t=8332
Moving the switch to the other side of the plate doesn’t make it hit the belt bracket? I didn’t do that because it looked like it would.
Does it matter if it does? Maybe it doesn’t?
It lands above the belt bracket… move it and you’re golden
