Im havin issues wirh the z plate getting loose frequently. I tighten thr eccentric nuts but seems like no matter what it starts to get sloppy after a bit. Can anyone tell ehT o can do to fix this or am i doing domething wrong possibly?
Talk to Mr. Beaver about his eccentric nuts. They should help.
Some folks put a bead of threadlock on the bolts, let it dry, then thread things together — once the bolt and nut are tensioned, use a hex key to turn it and the nut in unison.
