Y access stepper motor troubleshoot?
Question – I have a shapeoko pro that is about three years old and has ran great. The other day I was initializing and the left side Y access stepper began slipping or having a hard time keeping up with the right side and has gotten out of alignment. I did a quick troubleshoot of making sure the wires are connected….they were. Any suggestions would be appreciated.
Things to check for this:
  • pulley set screw — is it securely on the shaft?
  • belt — is it in good condition and properly tensioned/secured?
  • wiring and connectors — in addition to being connected are they all secure and in good condition and maintaining connectivity through a full range of motion? — check for that is to power up, leave the machine idle for 20 minutes or so, then check the temperature of each connector, they should be room temperature, if any are warm to the touch that indicates high resistance resulting from a poor connection
  • stepper driver (this is pretty unlikely) — a check on this is to remove both Y-axis belts, put a bit of tape on the pulleys (so as to more easily see their rotation), then power up, connect and initialize. The machine should home Z-axis as normal, then begin moving X- and try to move Y-. Do the Y-axis motors turn evenly and in synch? If not, power down and swap the connectors at the controller and repeat, does the problem switch sides? Power down and swap back and reinstall the belts swapping side-for-side and end-for-end if an inspection shows them to be in good condition, otherwise, get a new set of belts
Thank you I greatly appreciate the time and info. I will give these things a try.
Do this, one second check.
