Y axis coming up short
I have never used the lowest point of the Y axis although I’m pretty sure I remember jogging the machine the way to the bottom of the Y axis and it was past the bottom edge of the table.
Today I wanted to cut out some parts using a 24x48 sheet. I first thought I’d have to remove the Bitsetter to fit the 48 inch width. It turned out that my sheet was 47.5 so I reinstalled the Bitsetter and reenabled it,
I also reinitialized the machine and now I cannot move the cutter completely to the edge of the table. As the picture shows, it stops about 1/2 in short
. I can still move it all the way to the left on the X axis up to the edge of the squaring blocks you can see in the photo.
How can I reset the machine zeros? Thought I might go through a new machine setup but wanted to check here first to see what the problem might be,
Mike
Is
Zeroing is done per:
https://carbide3d.com/hub/courses/running-shapeoko/movements-zeroing/
How does your ability to position at the other corners relative to the MDF look?
I can jog the machine to exactly the corners on the MDF on the Y Axis. Both front corners come up short as shown. The X axis exceeds the MDF as it always has.
Check in w/ the folks in support.
If you’re willing to give up access to the back edge there is gantry shift:
I decided to run a new machine setup. I saw there is an upgrade to Carbide Motion so I installed that and did a new macine setup.
Improved somewhat; the back corners can be reached but still short of front corners on Y axis but a bit less, maybe 1/4-3/8 inch.
I thought my table might be out of square and rechecked it but seems square, certainly less than 1/16 on the diagonals.
I understand gantry shift can be used for cutting joints but I’d prefer not using that workaround and getting the full cutting area of the machine,
You should be able to see the physical limits. When the front face of the Y axis carriage (Red) hits the back face of the rail end cap (blue).
If jogging is stopping before these limits, check the soft & hard limit settings in GRBL, and the set limits for the machine.
$20 - Soft limits, boolean
$21 - Hard limits, boolean
$130, $131, $132 – [X,Y,Z] Max travel, mm
