Our Shapeoko 3 XL was going along, and suddenly the machine acted as if the Z axis Zero was 20mm higher than it was, even though Carbide Motion kept showing correct values.
Anyone experience this issue?
@austinious
If carbide motion is not reflecting the Z height change, then:
Check belt tension.
Check set screw.
Check the position, where you at the bottom of the Z travel?
What was happening when it happened?
I was machining a piece of .5" thick UHMW, using gcode from MeshCam. Program was about 60% complete, when the z carriage raised up by about 20mm and continued as if nothing was wrong. I quit the program, and jogged to the x,y and z using rapid position, and the carriage went exactly to where it was supposed to be. I separated the rough and finish passes into two different shorter files and will try those tomorrow.
I think I found the problem. My students have their work to low for the end mill they used. Basically, the carriage bottoms out, then jumps up a ways.
My fault for “assuming” they set it up right.
Thanks
@austinious
Glad to hear it was a learning opportunity, I like to say “measure twice, cut 10”
Im curious about this project now, if you can share what your classroom is making, post a picture when you can?
