Z axis grinding on initialize
If you turn the leadscrew manually are you able to move the Z plate down ?
If you can try and look into the space between the moving plate and the fixed plate. There have been a couple of cases on the forum of the leadscrew nut attachment getting loose, and then getting in the way of the movement.
EDIT: I mean like this:
