Z axis issue...HM001 error
Im getting a HM001 homing error. I have completed the TS as advised in the video. When in the debug menu the z axis led remains lit at all times. The inductive picked works fine when you pas a piece of metal in front of the switch…well at least the LED flashed. I did disconnect tthe 4 wire connector for the z axis and the radio button under debug still remain lit. I have contacted support but they are sometimes slow to get back to you and I was wondering what you guys think it could be. Im leaning toward a control board.
thx
When you disconnected the 4 wire connector, that was the motor. There should be another, 3 wire connector that leads to the proximity switch.
It could be the control board, but it could just be the prox switch.
ahhh…thx…Ill have another look.
Indeed, you are correct! The radio button under the debug panel does go out when I disconnect the pickup. Might just be the switch…thx.
I swapped Z to Y at the main board and the issue went to the Y axis. Im pretty sure it is the pickup now. I wish they would make ordering parts easier. Like just add them online!
Back in business…new limit switch installed and working perfectly.
