I had the same
This is why it took me so long to find the problem. Because they appeared very tight, and could not see movement I was looking for something else. I think that I removed the Z limit sensor plate and carefully looked at the shaft while I moved the Z with manual commands in CM. It was then that I noticed the 1/8 turn slip in the Z gear that was causing me all the grief for over a week.
