I always start off by saying I LOVE my Nomad. I bought it as a back up but it quickly became my #1 machine.
I have had this issue a few times and would like to find a way to resolve it.
During an engraving run a bit can break. I replace the bit, zero the new bit on top of the part, start the job again, the new bit buries into the work.
I can’t understand this since I just put the new bit on top of the work and told Carbide Motion, this is your new zero. Just as I did the bit that broke.
There was a time the bit broke and to avoid that issue I turned the machine off then on and started the initial startup process of machine wake up with the new bit. That worked fine for Z but X and Y were off a little.
So, what can be done that if a engraver bit breaks a new engraver bit can be inserted to finish the job without scraping materials?
Thank you
Jim
