Here’s the Gcode file, though anything I create in Fusion 360 seems to have this problem. Not yet tested with Carbide Create (since it’s unusable for aluminum). exp-origin-slot-top.nc (4.7 KB)
Maybe. Doesn’t make a difference. I wrote that there for the sake of anyone trying to reproduce.
My bitsetter was off before initializing.
By the way, I mentioned this before in another thread, and contacted Carbide directly about this… You can get this same problem by following their Hello World tutorial letter-for-letter: Shapeoko 3 - Hello World - Carbide 3D (truly a terrible first impression, by the way)
I thought this was useful as a non-destructive way of using the machine for the very first time - and it’s a quick and dirty way of seeing how well the machine is trammed - or not. I’ve not run it since, though
Hmm, I’m out of ideas because I’ve not experienced the same issue - although I’ve had others!
Also, I have no clue about Fusion360, but I assume you’ve selected the correct post processor?
I’ve never cut aluminium, but I seem to recall others have used CC for that purpose. For my own interest, why do you say it’s unusable?
Send $# through the MDI.
I’d just set G28, remove that line from your gcode, or disable it in Fusion as you Post Process.
I don’t know what this means but will try to find out. Does this recommendation imply you understand the problem, and if so what is it?
Thanks.
No ramping. And (though not specific to aluminum) no adaptive tool paths, and most importantly, no Rest machining.
Even if you accept the first two and resign to that limitation, trying to make a finished piece in CC without Rest options takes more time and hassle than learning Fusion 360 (no small feat).
G28 is a parking location. You can set that location. By default it is on your homing switches. That MAY cause your Z to go to high and lose steps.
You have a retract of 15mm, unless you have a long endmill very thick stock, that shouldn’t be a problem.
You’re also using a “Generic 3-axis” post processor. I don’t see anything that would cause a crash, though. I’ve never looked at that one, but you might want to try Carbide’s or Grbl (or mine…got a link somewhere on the forum).
Right now, I’d remove the G28 line and see if that changes anything.
My so3 acts funny after unchecking BitSetter in cm. Even if I really initalize. So maybe clear offsets will help
The funny part is I get an air job even after setting z zero and then unchecking BitSetter. Even setting z zero after unchecking BitSetter still produces air job. I need to power down and start over.
