Z Height engraving the bottom of a catch all tray
OK, so I have a valet tray and I want to engrave a name on the bottom of the carved bowl. The depth of the carved portion is.500. Once I finish the bowl carve can I just leave the x,y and z the same and change the start location of the engraving to .500? Hope this makes sense.
Thanks
Yes, this would work — you’d need to set up the file w/ a pocket operation to 0.5" which you would omit from the actual G-Code to preview things though.
Thanks Will. First tool path is the pocket down to .5’. I disabled that to preview the engraving. Obviously I will also disable that once I run the code. Thanks as always Will.:v:t2:
