When I try and home the machine the Z axis is not responding when it reaches the top. I had a faulty switch and did replace it thanks to Carbide. I have checked the switch and cable with a multi meter and all checks out. Just the board isn’t receiving the command when it hits the switch.
Any know issues with the board, Only had it a few months.
Not sure about why your Z limit switch is not working, but you need to set your max travel ($130 and $131). Yours are set to default SO3. Your X is about twice that if you have an XL.
Does the Z switch trigger an alarm if you press it during a carve (not during homing process)?
Try swapping the wiring and see if the Z switch will trigger if plugged in to a different connection (see if the problem follows the switch). It could be you wire from the switch to the board or it could be a faulty board.
I got a response from the Z switch which is responding the board just fine.
The X cable was plugged into the Z pins on the board, which produced nothing when pressed.
So it sounds like a board, cables are fine I did check the Z cable already with a mult meter.
