Z-Probe Adaption
I came across an INVENTABLES Z-Probe (30611-02) and was wondering if it could be adapted to use with the Shapeoko 3 XL.
Yes…but it depends on what you mean adapt though. It will work just fine if you issue probe commands via MDI in carbide motion, or use something other than Carbide Motion. If you want to use the probe page in carbide motion, then no.
Any conductive material of known thickness can be used as a probe block. You’ll just need to work out the wiring. The one you point to is specifically for the X-carve. You’re paying for their work to make those connections easier for the X-carve, but you’ll have to redo that part anyway.
