Z resetting after measuring?
This is a new one for me, but most of them are. I’m new.
I initialized my SO5.
I set my wood up on the bed.
I Put in the bit I wanted and zeroed my spindle (x, y, x).
I loaded my job.
I started the job.
Tool measures on bitsetter.
Job runs 6” above the z zero I set.
Whiskey Tango dot dot dot?
Anyone experience anything like this? Is it a know. Issue I am not finding in search? Am I that big of a novice that I messed something simple up? Something complex?
Thanks in advance.
Did you let Bitsetter measure the tool before setting zeros?
  • Verify that the Z Zero in your design file matches the Z Zero you set on the machine
  • If you disabled or enabled the BitSetter, exit Carbide motion and restart it, and then re-initialize the machine.
Must always hit the change tool button immediately after a cutter change.
The “Initialize” step should include measuring a tool if the bitsetter is enabled.
So your order should be something like…
I Put in the bit I wanted and it measured the tool.
I zeroed my spindle (x, y, z) .
I loaded my job.
I started the job.
Tool measures (again) on bitsetter.
Job runs right where it’s supposed to.
If you’re using the same tool to initialize & cut the first toolpath, check the Z value on the readout before it measures the tool, then again after it measures the tool. They should be the same.
Might need to click on “Position” and go into “Machine Position” to see a difference there.
If it’s the same tool, the Z position should be the same in work or machine coordinates. i.e. the tool length offset should not change.
