Hi there. All of a sudden when I set my z to a particular height by setting z zero, THEN when I do a rapid to z plus 6mm, it goes to more like z plus 25mm or so? Any ideas anyone?
My bit ero version 1 also stopped working a couple of weeks ago too. Related maybe?
Thank you so much Will. Checking all of this tomorrow. I so appreciate the help here.
I am using the bit zero version one, thought it seems there is only a drop down for version 2 in settings?
Shapeoko Z-Plus, I installed about 60 days ago or so.
Okay so I decided to remove my version of carbide motion from last November and reinstall the latest one from the carbide 3D website.
Everything now seems to work perfectly with the exception of the following two items
My bit zero version one worked he first time I tried it but then does not work and probe failed again
This is pretty weird as it works first time and then stopped working again
So it appears I do not now have any problem with setting the z zero the rapid command to go to zero + 6 mm does not seem to be accurate
It goes to z 0 plus .236
Guess this does not matter
I will keep you posted if I have any other issues but I wonder if this is anything to do with the fact that I’ve just started using the v-carve desktop?
As usual thank you one and all for helping what a great community to be part of
So if you set zero at an arbitrary height, somewhere in the middle of the Z-axis range, and then immediately click the ‘Z-Zero + 6mm’ (or however it is labeled) button, it does NOT move up 6mm?
