Pro xxl, when zeroing once I set zero and then hit zero out the z axes do not zero and the machine goes to home and the Z axes jams into the waste board. Please help
Does it indicate that it is going to measure the Z-axis?
Did you configure the BitSetter in the Setup Wizard?
https://carbide3d.com/hub/docs/shapeoko-setup/
Try disabling the BitSetter?
I am using the bit setter. And I’m not sure if it says it’s measuring Z axes . Do you think it could be an older version of software issue?
I would recommend re-running the Setup Wizard and configuring the BitSetter position.
If that doesn’t work, let us know step-by-step:
- what you did
- what you expected
- what actually happened
