Connected font sign
(Tom) #1
What is the best way to do connected letters/1 peice words? My wife wants me to make this and I know I can do it but will likely make it much harder than it has to be!
Also any ideas on what font this is?
(Tom) #2
Oh yeah I have Aspire - is this an option? At work thinking about this and don’t have my laptop.
(Josh) #3
You could draw it out on paper, take a picture, bring it in to inkscape to create an svg, then use the svg in create.
Or just overlay the letters in inkscape, manually. I think you can do this, I’m still not well versed in inkscape. Not really sure on the font.
(William Adams) #4
Looks like hand lettering.
If you used a font, you could achieve a similar effect by:
  • distorting / scaling letters
  • overlaying them so that they connect
  • Boolean union
There’s a bit of a discussion of some of that sort of thing in: Could use some guidance on creating a carve
and be sure to see: http://docs.carbide3d.com/assembly/carbidecreate/video-tutorials/#boolean-operations
(Adam Albert) #5
If you have a font that you like, you can use the text tool in Aspire to create each letter as a separate vector. Stretch/Skew/Rotate as desired and move each letter into position. Finally, use the scissors tool to cut the vector segments that are inside your overlapping areas; be sure the “connect vectors” option (or whatever its called) is checked in the scissors tool.
(Stephen Gullage) #6
Quick and dirty attempt at it https://drive.google.com/open?id=174enOqf6jwRcCGXrEro3sQJnyS1WdVmq
Otherwise, Mother’s Touches Font is kinda close but you’ll have to do some editing. https://www.dafont.com/mother-s-touches.font?fpp=100&text=EXPLORE
(Tom) #7
That looks great Stephen!! Thank you!!
This forum is awesome - Thank you all for the help!!
(Jesse Glessner) #8
Check out the APP, WhatTheFont at:
It supposedly will supply the font name OR give you the closest font to whatever is shown.
(Jerry Gray) #9
Also with Aspire you can take a picture, import it, trace it, scale the vectors to a certain size, then “profile tool path”, the vectors.
