Whilst testing carbide motion 4.10 last night my crocodile clip broke. Not loving it I decided to ‘improve it’ (I still think it’s the best thing since sliced bread but now it’s home grown).
Here is a video I made last night.
Happy to supply anyone with a magnetic connector that can be soldiered on to the wire, or provide a whole new wire if anyone wants one made up. Alternatively, I’d happily supply to carbide 3d if they saw it as a worthwhile medication to the new probe? @robgrz
Now why the heck didn’t I think of using a magnet?! I’m here cursing the cheap gator clip… Now the question is… how exactly did you affix the wire to the magnet? Surely not solder? Hot glue and shrinktube?
Solder the magnet to a piece of ferrous metal, a washer maybe, then just stick the magnet to it?
I have a bunch of these from a project that fell through, a #4 screw can go through the middle, be epoxied on the other side, then the wire soldered to the screw.
Instead of supplying a connector, can you describe how you connect the wire to the
Magnet? I am guessing that it is a moledbium (rare earth) magnet? Did you just
Solder the wire to the back of the magnet and then heat shrink tube the assembly?
Always happy to help. I got some 6mm bar, drilled out the centre, poped a wire in one side, a 5mm magnet in the other side then compressed the one end in a die press making a sheath - then soldiered the other wire onto the earth cable and heat shrank it
2 options. Grab a button cell holder for electronics and use that to hold a disc magnet, or get a rare earth magnet with a hole in it already (they are made like that) and just run a screw and a ring connector to it.
