Thanks Griff
I actually laughed out loud at that
Thanks Griff
@Luke Thanks for sharing the design! I donât know that Iâll go down this path, but youâre making it enticing. Are you updating the design on A360? The plate looks like itâs missing some holes. Also, I think the issue with the thin âMotor Mountâ plate not appearing might be a naming issue as you have another part named âMotor Mountâ. Fusion keeps a version history, and I think the common name is throwing that off.
@Griff Either of you guys made any more progess?
Again, thanks for sharing.
Yep itâs all done in fusion. I didnât add the vertical holes for the guide rails as I wasnât sure on the spacing. Whilst @Griff had 30mm from the top and 60mm between I had 25mm from the top and 60mm between. It should be a simple add.
Thanks for the tip on the end stop
@neilferreri still waiting for my last component, the ball screw. All else is complete.
I added a set of holes to the 611 mount to enable some vertical mount height flexibility.
Really looking forward to installing it and seeing how much of a machinist I am
Finally!!!
The ball screw delivered. Should have all installedâŠsoon.
Iâve acquired an additional distraction, a Prusa Mk3 3D printer kit.
Although, now that I think about it, is not so much of a distractionâŠthose prints take one hell of a long time!!
Stay tunedâŠ
Yes, they sure do. In my old house I had mine in my âofficeâ, and the stepper motor âwhirringâ noise just drove me bat $#!+ crazy. Now that Iâm doing the CNC router thing at least itâs a more constant sound and the machine time/size of product is more âslowinstantlyâ gratifying. At work we have a large format printer (meter x meter x 1/2 meter build envelope) and they run prints upwards of 100 hours (and this thing is scary fast). Iâve seen them burn through 3-4 3kg spools on one print, how would you like to wait for that!
Dan
Funny you should mention noiseâŠthe Prusa Mk 3 isâŠvery quiet . Plus, I have it in a box to keep the dust away (itâs in my shop) and to enable ABS and PC prints, which makes it silent, really.
I have an open delta printer (Rostock Max V2) and a closed up Cartesian Makerbot clone. Neither is very loud, actually pretty quiet, but itâs the pitch of the steppers that bugs me. Itâs weird, Iâve worked in sheet metal shops for a long time and the sounds of grinders and sanders on metal doesnât bother me at all (have some midrange hearing loss though). If Iâm eating dinner with my kids and someone scrapes a fork on a plate I nearly jump from my skin, itâs similar to the sounds of the 3D printer in my ears, like nails on a chalkboard almost. The ShapeOKO noise doesnât bother me either unless I have feeds/speeds way off, but I have adopted some hearing protection as of late to save whatâs left of my hearing. Anyways, rambling at this point. How is the new Z coming along? I still have my original CNC4Newbies slider sitting on the bench, I may never install it, haha!! The design you and Luke have been working on looks superior to be honest. Very cool stuff!!!
Dan
After some flailing and maybe a curse or three, Iâm at the point where I can begin dialing in my new Z.
Thank you Luke, Mr.Beaver for the design.
Congrats, Griff, it looks like all your work has started to pay-off.
Rockinâ and Rollinâ buddy!!! Now get back to making cool stuff so I can live vicariously through your awesome wood projects!
Dan
What software do you use to work .
Iâm dabbling with CNCjs and UGS.
Does CNCjs support homing yet?
Awesome work. Time to see the results⊠How did the tramming bracket work for you?
CNCjs does support probe. In fact, here is a macro @neilferreri kindly provided to me:
This one will probe Z first, so you donât have to mess with changing distances. You can paste the stuff in parentheses with it as a reminder)
(start with the end mill 15mm ABOVE the plate, about 15mm or less from bottom left corner.)
G21 ;make sure weâre in mm
G91 ;Incremental mode
G38.2 Z-25 F75 ;Probe Z
G10 L20 P1 Z22 ;Set Current Z as 22mm - thickness of your plateG
G0 Z3 ;lift Z 3mm
G0 X-25 ;Move left 25mm
G0 Z-10 ;Move down 10mm, should be 7mm below probe surface
G38.2 X25 F75 ;Probe X to the right 25mm
G10 L20 P1 X-10.175 ;Set current X location as negative half the bit diameter - 7mm thickness
G0 X-10 ;Move left 10mm
G0 Y-25 ;Move forward 25mm
G90 G0 X5 ;Move to X5 (absolute) - will put you 5mm to the right of left edge of stock
G91 ;incremental
G38.2 Y25 F75 ;Probe Y
G10 L20 P1 Y-10.175 ;Set current Y location as negative half the bit diameter - 7mm thickness
G0 Y-10 ;Move Y-10
G0 Z10 ;Move Z up 10mm, should be 3mm above probe plate
G90
G0 X0Y0 ;Go to X0Y0
@neilferreri has also written one for tool length offset, "Automatic" Tool Length Offset
The tram/router alignment design is brilliant. Using machining blocks I was able to level the mount in seconds . Today I will use the technique you posted to finish up. Then itâs back to doing useful work!
Oh awesome, I didnât realise it did (I didnât see the tool pane) I will sure be taking a second look at CNCjs.
Iâd love it if if the probing was a feature of the software rather than a macro. I find myself swapping bit sizes all the time. I guess I could have a number of macros for each bit diameter?
I have ran into an issue - I canât save any macros
Hit up @neilferreri, heâs the expert here!
No expertâŠjust hacking around.
@Luke What happens when you create a macro?
Also, I believe the developer is working on a probe widget that will allow for an axis other than Z, but I donât know if it will be a true 3-axis probe.
The really cool thing about the cncjs macros is the ability to use user defined variables. You could do something like below with only one line item to change (NOTE: Untested).
%ENDMILL_DIAMETER = 6.35
%ENDMILL_RADIUS = ENDMILL_DIAMETER /2
G0 Z3 ;lift Z 3mm
G10 L20 P1 X[-7-ENDMILL_RADIUS] ;Set current X location as negative half the bit diameter - 7mm thickness
G91 ;incremental
G10 L20 P1 Y[-7-ENDMILL_RADIUS] ;Set current Y location as negative half the bit diameter - 7mm thickness
G0 Y-10 ;Move Y-10
G90
G0 X0Y0 ;Go to X0Y0
Quick video showing how to make a macro.
@neilferreri, as a teacher you will appreciate if I say learning has occurred. I am proud to say I have improved my understanding of CNCjs from the level of zero to now being able to set up jobs and easily navigate around the workspace.
I think I deserve a gold star .
Oh, also, your tool change macro works great, thank you.
Thanks for the video, itâs not user error. When I click add it just saves but nothing is saved/added to the macro box
