Possible Bug with multi-tool jobs
(Daniel Loughmiller) #1
Curious if anyone else can reproduce.
  1. Create a CC job with multiple tools.
  2. Start the job
  3. Before the job reaches the point of needing to change tools, stop the job.
  4. Retract the Z axis until it presses the limit switch
This produced the dialog for me to insert the second tool even though the job was stopped.
(Richard Cournoyer) #2
Shapeoko, Nomad???
Sorry, you haven’t provided us with enough information (Why? Because the answers are different)
(Daniel Loughmiller) #3
Appologies, Shapeoko, latest CC build and I’ll get the CM build next time I’m downstairs but I updated it not long ago I believe.
(Richard Cournoyer) #4
OK, Shapeoko is the info I needed:
This is a typical newbie error. You CANNOT do a tool change (muli-tool in one) program.
Each tool is a separate program (for now and the foreseeable future)
Here is some training info you need:
(Daniel Loughmiller) #5
I was actually aware, in this instance I was running a job with 1/8" mills but I had a ‘fake’ mill with a slightly higher diameter to get it to make a path that left material for a finishing pass. I was merely suprised to see the dialog to change tools even after I stopped the job.
(William Adams) #6
It should be possible to do tool changes on an SO3, so as to accommodate the folks who use depth collars and find their accuracy / precision adequate for a given project. I’ve asked a developer to look into this — hopefully we’ll get an official answer on this later this week.
