V-Carving a Background Image?
(Ed Landphere) #1
Hello,
I just purchased a Shapeoko 3 and am wondering if I am able to V-Carve a background image? The image is a business logo. Any information would be greatly appreciated. Thank you.
Regards, Ed
(Michael Salzlechner) #2
kind of hard to answer without seeing what you are trying to vcarve
vcarving simply uses a v shaped bit and cuts as deep as needed to get the width between the vector lines. But depending on software you can also limit the depth and so get v shape outlines and a flat bottom possibly combined with a flat bit to clear the flat areas
you would also have to convert your logo to vectors if you dont have vectors already
(William Adams) #3
Yes, but it won’t depth-limit. See
