I don’t know if it’s a problem with my end mill, my machine setup, or just my luck. I don’t know what to do to fix these uneven edges. Does anyone have suggestions?
I’ve seen this before and it was an issue with the actual angle of the V bit versus what the cam thinks the angle is. I haven’t used carbide create but double check that the angle is set correctly, and that CC isn’t looking for 45 degrees (half the total angle) rather than 90 degrees
