2.2KW Spindle with Half Inch Cutters?
Hello!
I recently did an upgrade on my Shapeoko XL to the HDZ with 2.2KW Spindle and new belts as well. Looking forward to upgrading to aluminum waste board soon. I was wondering if anyone used Half inch cutters with this or is the machine rigidity not enough to handle that for 6061 Aluminum. So far I been using a 3 flute 1/4 end mill and my adaptive are 0.25 DOC and 0.025 WOC with a 1-2 thou chip load with no real issues but as soon as I increase the DOC to 0.35, it starts struggling.
Any advise? Thanks!!
I never used a 1/2" cutter so can’t comment on that, but I would advise to first try a 1/4" single flute (e.g. #278Z), they have been working much better than 3-flute for me for roughing in aluminium (since they are basically uncloggable, which means you can go deeper with lower risk). I have done some adaptive cuts up to 0.5" (not that it makes a lot of sense, but it was fun seeing those loooong chips forming)
Yea, I been reading a lot on single flute cutters. Yes, the issue with going deeper is I need to increase RPM and the 3 flute just starts clogging up even with the proper speeds and feeds. What are your RPM set to when you do the 0.5 DOC and whats your typical WOC for adaptive?
I been having trouble getting the right speeds and feeds.
Thanks so much!
Something like this:
  • Maxed out RPM (=minimize cutting forces, and bearable noise level when using a spindle)
  • 0.001" target chipload (as usual for aluminium)
  • 5% WOC (more typically 10%, but for a very deep cut it makes sense to back off a little on optimal load, I think)
  • which once chip thinning is accounted for, calls for a feedrate of 55ipm.
Do you think something like this would be achievable with the single flute?
That’s a larger chipload than I like to use, but it should be doable. Since it depends a lot on the machine/setup, I would try with a smaller WOC/DOC first and then incrementally work my way up to those values. The machine will tell you when it can’t take it anymore.
If you are looking at optimising MRR and figuring out how far you can push things, you should definitely use @gmack’s worksheet to have some feedback on the amount of power/deflection for a given set of cutting parameters
Thanks for the feedback. I will have to wait for some aluminum stock to try it out. I ended up getting the calculator but I am not sure if I am using it right.
I am not exactly sure what the K factor should be some are putting 1.76 and the NYC CNC suggests 3.6 ish as the K factor for 6061 aluminum.
Also, I am not sure if the other numbers are correct either.
If you could offer some help that would be great, Thanks!
Use 3.344 for k factor
If your pride is directly connected with axial doc…you’re gonna have a bad time. If still using V wheels, a high radial low axial is most likely going to get you max mrr with a “happy” machine.
The question… does anyone make 0.500 single flutes lol
I have yet to upgrade the V Wheels to linear rails. I actually been looking into that. What would you say is the max DOC if I were to stay with V wheels while keeping my machine “happy”?
Thanks
I would try running at a 0.025 axial, 0.230 radial at 24krpm and 100ipm. That will net you a 0.0014 chipoad and higher mrr with less force than your high depth cut. Also you’ll probably be able to feed override it almost to 200% depending.
Bonus thing about cuts like this is the floor finish will tell you exactly what the machine likes. Each cut is different, it even depends on which direction you are cutting.
Ide think about some 0.375 endmills to effectively increase your sfm a bit. Bigger shank really helps when sticking it out there as well.
I see. Based on your IPM, I assume this on a quarter inch cutter with 3 flutes. What about the advantages of single flute?
Yep, this.
The Shapeoko has a whole series of mechanisms of deflection and they are absolutely not symmetrical between X, Y and Z.
Floor finish is key not just from the horizontal movement but due to the coupled Y-Z nodding movement of the Z carriage on the V wheels tracking the X rail.
You’ll learn the sound pretty quickly, I’ve found that fiddling the spindle speed and feed rate can frequently get the machine out of a resonance mode, it’s not always going slower that’s the answer and I’ve found that, for example, 22kRPM works a lot better in X traverses than 20kRPM for single flute cutters, that’s just the harmonics of my Z carriage and spindle.
And that’s also not even getting into different tool balances/geometry. Its an interesting game for sure.
A 3/8s, chamfer tip Destiny Diamondback would probably run very well at 20krpm.
If chip clearance/evacuation is an issue then try less flutes.
I used Kennametal’s 1.76 K-factor for that endmill with the cutting parameters shown in the workbook. The cutting parameters were chosen to minimize cutting forces while keeping within Kennametal’s calculated acceptable operating range for the endmill. Similar parameters for the 1/2" version of that endmill are shown here. If you compare predicted performance with the 1/4" endmill, you’ll see that the 1/2" endmill should further decrease cutting forces. (They should be cut in half at the same MRR). Chip clearance should be improved with the larger endmill too.
I’ve learned from @spargeltarzan and others that K-Factor is dependent on much more than the just workpiece material. Cutter geometry (rake angle, edge radius, helix angle, etc.,), chipload, and the use of lubricants can have a significant impact on it. So, calculators that consider those factors should provide much better estimates of milling performance. Kennametal’s probably does that, as does the “new kid on the block” Millalyzer.
Be interesting to see more about at what size the multi-flute cutters become more effective than the single flute in non-clogging, dry chip evacuation. As the cutter gets bigger the flutes between the faces get bigger and if you’re doing n cuts per rev instead of 1 cut per rev then presumably your chips can be smaller at the same MRR (i.e. not having to push to max per tooth cuts).
I ordered a 10mm 3 flute to play with.
Why stop at 3 flute?
To walk before I run? :wink:
Do you run that dry or with air blast / lubricant?
Haha, I understand that. However I personally couldn’t pass up this tool deal before its price goes back up to $100.
I’m actually 100% dry nowadays, ya know, smaller sweetspot, really put cam to the test. Probably should learn how to use the Millaylzer one of these days.
That looks like a nice cutter, once I’ve done the linear rails maybe…
I nearly bought this;
but figured I’d stay uncoated so I could see the result of just changing the no. of flutes from the single and two flute 4 & 6mm I’m running at the moment;
https://www.shop-apt.co.uk/3-flute-carbide-end-mills-for-aluminium-45-helix-uncoated/3-flute-carbide-end-mill-for-aluminium-10mm-diameter-45-helix.html
It’s cheap enough to experiment with.
So far I’ve managed to make the 2 flutes work really well on exterior adaptive clear and contour where they can throw the chips away from the workpiece but still learning how to keep them happy in a pocket. I’m also being stingy and working my way up the DoC instead of the WoC because I’d like to use more than the bottom 1mm of the cutter.
Whilst you’re here and we’re talking big cutters…
What do you use for facing with?
Have you found anything with inserts that will run in ER20 size collets that’s actually balanced?
I saw these sorts of things;
https://www.amazon.com/12Pcs-C12-12-130-Holder-APMT1135PDERDP-Wrench/dp/B07QGBKQTJ
But in the 10 and 12mm sizes they appear to have a single insert and don’t exactly look like a balanced tool for high speed spindles.
