I am using Carbide Create Pro 472.
I am making a frame (10"x10") with a large center cutout (9.5"x9.5") that will be discarded.
I thus have two contours, one on the outside of the frame and one on the inside for the cutout.
I need the inside corners sharp (as if cut with a 1/8 bit #102).
The outside corners are fine (as if cut with a 1/4" bit #201).
I have a bitsetter.
Am I best to design three toolpaths.
- Cut inside shape with the #201
- Cut outside shape (with tabs) with the #201.
- Cut inside (same shape as 1) with the #102.
I note there is a 3D Finish and 3D Rough. Is using this a better way of making these cuts? Are there any tutorials on using them? I have only found older ones pre 3D Finish
stay well.
Shapeoko has helped keep me at least semi-sane during this lockdown. thanks,
Richie
