KevBarn14
(Kevin Barnett - Carbide 3D)
July 18, 2022, 4:21pm
1
Hey Everyone
Here’s our latest video. Looking at some tools that can be made on CNC. We would love to hear what tools you here on the forum have made and utilized. Let us know what’s worked for you.
WillAdams
(William Adams (Carbide 3D))
July 18, 2022, 4:36pm
2
One thing I would urge folks making tools w/ measuring marks to do is to calibrate the machine:
The typical technique for machine calibration:
https://my.carbide3d.com/faq/belt-stretch/
depends on precision measuring tools, and is limited by the reach of the tools in question.
EDIT:
It also depends on access to the MDI — if using Carbide Motion v6 it will be necessary to enable this in Settings | Options:
[image]
It should be possible to cut strips from a suitable blank of material, one along each axis — so we set up a square file which matches an available blank of material:
[ima…
My first project on my SO3 was a pair of locking register calipers:
Hope things done on a ShapeOko 3 are okay:
(Note that the projects page below is off-line)
Source file:
[Tool_calipers_locking]
CAM done using MakerCAM and F-Engrave.
Parts list: 6061-T6 aluminum, brass Chicago screw, #8-32 screw, #6-32 screw (may need a divot filed into it), and a knurled #6-32 thumb screw
Cut on a ShapeOko 3 using a Makita RT-0701 and 1/8" bits, feed 215mm/min., plunge rate 27mm/min., 0.2mm cutting depth.
A further consideration if you make a lot of tools is storage:
(and it’s a lot easier making the file to cut the foam insert when you already have it from making the tool)
HaroldO
(Harold Osmer)
July 18, 2022, 8:07pm
3
Thinking out loud…if you belong to a woodworking or metal group, why not make some of these items with your buddy’s name/initials or shop logo on them?
KevBarn14
July 18, 2022, 11:46pm
4
Personalization always wins Harold. Great Call.
system
(system)
Closed
August 17, 2022, 4:22pm
5
